![]() | Home > In Car Electronics (L322) > Radio / head unit keeps turning off and on |
| Dinners Member Since: 15 Feb 2015 Location: Nottinghamshire Posts: 6
as the title really, start up today and the head unit loops into turning on and off.
| clemenz Member Since: 13 Sep 2014 Location: Graz Posts: 183
battery ok? |
Had a new Battery and alternator in Feb this year.....so I had ruled that out. |
ok thanks.
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6433
An '02 is a different kettle of fish!
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3988
^^ + 1 |
| Balloonengineer Member Since: 03 Sep 2017 Location: Kent Posts: 180
I was watching Stephen Kings Christine last night. If yours plays 1950's rock and roll when it does, I would be worried...…….. Previously......
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8788
try a battery reset, mine went into looping on and off on my 07. did it for a few days, disconnected the battery and did a battery reset and all was ok after. though whether that was the reset which did it was up for debate. There is nothing that can't be fixed with a hammer😜😜
| jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 299
Mine was doing exactly the same checked everything in the boot all connections by passed each unit one after the other to check for faults all ok. I then noticed last of all when I was checking the back of the main head unit there was a TV on the move module fitted to the radio receiver behind the main touchscreen head unit I disconnected this and my stereo has been fine ever since now random restarts etc... So it was a faulty TV on the move module. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
| Biggles1957 Member Since: 05 Dec 2017 Location: Leicestershire Posts: 28
I know you said no sign of water ingress but have you pulled the plugs and examined the contacts? Mine all looked bone dry but had obviously had water in there at some point in it's life because the contacts showed signs of corrosion... |
