Home > Technical (L322) > No Heater 2007 L322 TDV8
nick4275
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
The heater has stopped working in my 2007 TDV8 (ford)
I've bled the system as you normally would but still no heat.
So I took off the pollen filter and checked the heater pipes as they enter the matrix - they are cold
I then took off the pair of clip-on water hoses on the top of the engine that feed the heater and water is being pumped out of the feed pipe.
So I now know water is getting to but not getting round the heater matrix.
The only component before water reaches matrix is the "heater valve" - so it could well be this but I have no knowledge of how to prove it
Does anyone have any tips as to testing this item or the symptoms you get if its faulty ?
It may not be this at all so if you have other thoughts please share them !!
Post #490199 28th Sep 2018 12:59pm
Sandyt
There are a couple of valves on the inner wing near side mine failed last year there is also another on the bulkhead it ended up being the one on the bulkhead which I only discovered after changing the others. To be honest I went the whole hog and changed all the valves and hoses as they were 10 years old
Hope that helps
Post #490225 28th Sep 2018 6:39pm
