![]() | Home > Technical (L322) > First time Restricted Power Mode - Caravan Attached |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8065 ![]() ![]() ![]() |
Hopefully this thread might help |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Would be checking the small top plenum to manifold hoses first. Sounds like a boost related issue. There is nothing that can't be fixed with a hammer😜😜
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3854 ![]() ![]() ![]() |
I agree with NMJ.
nambFFRR Member Since: 07 Aug 2018 Location: United Kingdom Posts: 213 ![]() ![]() ![]() |
Thanks guys.
gilesharrison Member Since: 04 Aug 2018 Location: Cumbria Posts: 163 ![]() ![]() ![]() |
Hopefully a hose leak but have a look at my recent thread.
gg2201 Member Since: 21 Oct 2013 Location: Callington Posts: 158 ![]() ![]() ![]() |
As above mine went and we replaced all four as mine had the original hoses and the replacement design is far more robust!
Looks like an easy (!!) check. Tomorrow looks like it’s going to be interesting if I can get the caravan home first!!! Wish me luck..... |
Removed the top plastic cover and everything is bone dry and no evidence of any splits or leaks/soot
The plastic manifolds can also crack that will normally be where the plastic is bonded together. Soapy water mix and the engine running might show this up should bubble if there is leak.
Under the cover everything looks brand new. I couldn’t see any splits but didn’t try the soapy water test. Fault has cleared again so it off to the supplying dealer this week. I’ll update the thread if the fault is diagnosed. |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
You wouldnt get bubbles from the soapy water because the engine wont be on boost? BMW i3 Electric Car
Can still bubble on tick over or a good rev, you can see below
Do you know what code is thrown up by the plenum/rubber leaks? |
A good rev I can understand it bubbling only whilst the turbo(s) are boosting though, at idle there wouldn't be any pressure there at all IMHO. BMW i3 Electric Car
