![]() | Home > eBay & Bargain Spots > 12v trickle chargers at Aldi |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Dont be under any illusions about the ALDI charger it is nowhere near as good as a CTEK. Ive got both and I did a mini review for the caravanning fraternity.
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1672 ![]() ![]() ![]() |
As a layman all seems pretty much good quality to me. Like you say it charges the battery.
As far as I know the Aldi doesn’t have the capability to charge in cold conditions, recondition batteries or act as a PSU which my CTEK does. BMW i3 Electric Car
S.Hafsmo Member Since: 02 Oct 2018 Location: Nordland Posts: 170 ![]() ![]() ![]() |
The Ctec isn't withouts it's faults though. I've got 3 of the them, and have had issues with them all. Some won't charge when they are cold (must be brought inside to heat up first), some require multiple attempts to actually register that it's supposed to start charging, some just stop charging half way, and must be re-started.
You’re the first one I’ve ever heard complain about Ctek. Every day an education! BMW i3 Electric Car
V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 424 ![]() ![]() ![]() |
I have 3 C-Teks and 2 work perfectly. The other has stopped allowing me to change the mode which is not too terrible as it's stuck on the regular charge mode with the car icon.
The 'current' (forgive me) Aldi one has a fast charge 6v standard mode, a 12v 0.8A standard charge mode a 12v 3.8A fast charging mode AND a 12v 3.8 Cold charge mode as well as the trickle charging. The manual also confirms a reconditioning and reactivation function as well as the usual overheat cut out and polarity protection.
I may just go and get another one and have a look, thanks for the info. BMW i3 Electric Car
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8778 ![]() ![]() ![]() |
my Ctek just went pop.....
Better get the hammer out to fix it then! BMW i3 Electric Car
yep.....
Care to send it to me, I can probably repair it ? BMW i3 Electric Car
was thinking of having a go, putting my D at electronics A-Level to the test, but its gone now unfortunately, went bang a few weeks back. did cut the wires off tho.... so I have some spare connectors
