Home > Maintenance & Mods (L322) > Correct towbar for exterior design pack?
Danwilderspin
So I have the exterior design pack on my ff . I wanted to put the detachable towbar on so I naively found one off ff braking genuine one. Anyway got it on today after a lot of swearing but the attached is still low and I cant put the plastic trim on the bottom on... is there anyway I can make this work? I’m thinking of cutting a notch out of the trim panel hopefully it will be less visible then...
 Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #493789 27th Oct 2018 6:51pm
you could make the whole thing removable, and just fit it when needed. Or use a farmers hitch. There is nothing that can't be fixed with a hammer😜😜
Post #493855 28th Oct 2018 11:54am
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
There should be a cut out line on the plastic Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #493859 28th Oct 2018 12:26pm
Danwilderspin
Do you mean in the lower plastic panel held in with 4 clips? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #493915 28th Oct 2018 6:55pm
Bushy30
I do indeed Sir, there are other posts on here that suggest there is a clear line to cut to, I think CamTechCraig was the one mentioning it Smile Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #493925 28th Oct 2018 8:12pm
Danwilderspin
This square line? I will try it - but then I’ve got to ask was the point of taking the middle cover off above it? So you don’t scratch the number?
 Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #493949 28th Oct 2018 11:01pm
mm289
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Ipanema Sand
Hey Dan, have a look at this thread.http://www.fullfatrr.com/forum/topic48695.html I had a westfalia swan neck detachable fitted to mine a couple of weeks ago. The only thing I can't figure out is how to access the sockets - I can see them inside the bumper but can't figure out how to get to them Big Cry
Let me know if you would like some more pics Thumbs Up
Cheers,
Paul.[/url] 2011 TDV8 AB
2006 TD6 AB (Gone to Wales)
Post #494082 29th Oct 2018 10:10pm
Danwilderspin
Cut it at lunchtime - it’s still fairly visible though is that right? I thought the point was to hide it? Also can’t access the electrics do they need moving?
 Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #494140 30th Oct 2018 5:26pm
Yes thats the correct fitment... The panel needs removing every time you use the tow bar... The small panel above that can be removed as to not scratch it when docking trailers... Thumbs Up
When i had mine i plugged a separate tow bar electrics loom in behind the righthand inner fusebox cover panel (inside the boot) i then simply plugged a long springy extension from my trailer into it... I simply closed it into the corner of the lower tailgate Thumbs Up
Post #494169 31st Oct 2018 1:06am
Danwilderspin
Thanks Craig I was thinking that was the way last night - typical LR laziness lol they want to the trouble of concealing 90% of the towbar with that bumper why didn’t they blow the cover slightly thicker to hid it totally Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #494172 31st Oct 2018 8:37am
