| Key Fob / Central Locking issue *** FIXED *** | |
RR Vogue 3.6TDV8, registered year 07 (MY06)
Problem:
Remote fob unlocking / locking stopped working (flat fob battery?)
Key in driver’s door, one turn unlock driver’s door second turn unlock all doors still working
Then after a while the following:
Key in driver’s door, one turn unlock driver’s door (not the same sound), second turn nothing. Open door alarm beeping until key placed in ignition (not turned just inserted), beeping stops, remove key put back in driver’s door now activates central locking (still takes two turns to unlock all doors)
I thought it was just that the fob batteries were completely dead so got a replacement battery in one key fitted by RRUK, but still the same.
Both keys behave in the same way (key with new battery and old key with flat battery)
My question is:
Will the procedure below for pairing the fobs to the locking system fix this?
1. Insert key in ignition and turn to position 2 then remove key (within 5 seconds )
2. Hold the unlock button for no longer than 15 seconds, whilst holding the unlock button press the lock button 3 times, release both buttons and the central locking will lock and unlock the doors to confirm it has worked.
3. To do another key, repeat step 2 with the second key
Also this procedure says key to position 2 but I have seen others that say position 1 (which is right)
Or am I looking at BCU problems? Transport Mode?
I have search the forums for the problem but can’t find anything the same as I am experiencing.
Thanks for any help you guys can provide.
