Home > Maintenance & Mods (L322) > EGR Blank TD6 Advice
gj88
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Hi all. Got a blanking kit winging its way to me as we speak after seeing some of the other posts and walkthroughs that have been posted here over the last week or so. Had a quick poke under the bonnet last night just to make sure I know where everything is (admittedly in the dark) and just had a question about the easiest way into the exhaust manifold. Instructions seem to suggest taking off the airbox, but I was wondering if it was reachable from the underside and I could therefore save the job of taking everything off? Also, anything to be aware of with this job on a Td6, all the good write ups I've seen are for the bigger engine. Cheers!
Post #495905 18th Nov 2018 4:47pm
1. Remove front engine cover
2. EGR valve is top right of engine at the front.
3. Pull off the rubber vacuum hose
4. Undo the jubilee clip to the EGR cooler
5. Undo the 4 torx/allen bolts holding the EGR in place
6. Remove EGR
Replacement of the blanking EGR should be roughly the reverse of the above. If it doesn't provide a place to refit the vacuum hose, use a golf tee or similar to plug it. .
Post #495907 18th Nov 2018 4:55pm
gj88
Thanks Joe. I was pretty comfortable with that bit (useful to know I'm not missing anything though!), but the bit I'm less sure about is the diamond shape blanking plate (pic attached). Assume this needs to go on the exhaust manifold, but it doesn't seem easily accessible. Is it an unnecessary step, or am I just missing something obvious
Post #495909 18th Nov 2018 5:39pm
Hmmm, it is for one of two things:
http://www.fullfatrr.com/gallery/displayim...amp;pos=34 (big effort)
or
http://www.fullfatrr.com/gallery/displayim...amp;pos=28 (little effort but unlikely it is this)
Suggest review my photo howto for thermostat which pulls all EGR parts off. You will see it is a bit of a job!
http://www.fullfatrr.com/gallery/thumbnails.php?album=380
FWIW my EGR blanking kit was quite different to yours with just the rounded "pennies" to block off the gas flow into the EGR, and a spike to put the vacuum hose onto. Never bothered with blanking off further down .
Post #495926 18th Nov 2018 7:18pm
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
The one you bought seems too much mucking around, you can get them which are simpler, just remove your exisiting one, fit this type in its place exactly how the old one was fitted. it looks O.E so inspectors won't know you have removed it.as pipes are still there, no blanking plates required like yours.'
[img]
[/img]
Post #496740 27th Nov 2018 12:09am
Swipe
United Kingdom 2004 Range Rover Autobiography Td6 Java Black
Done this to my TD6 a couple months ago very easy job no fault codes.
Used the same as @lounge_on_wheels img.
Post #496742 27th Nov 2018 12:24am
Fraynizzle
United Kingdom 2005 Range Rover Vogue Td6 Java Black
Its Vacuum controlled so just plug the hose from the controller to the EGR valve.
you can just stick a screw in the hose.
would the EGR still operate on pressure difference from exhaust to atmosphere (where vacuum hose is no longer)?
Post #496760 27th Nov 2018 12:01pm
