Home > In Car Electronics (L322) > 2007 Sat Nav diagnostics
uzp315
Hi all,
a while back I came across a thread with someone accessing a diagnostic screen for the sat nav on a L322.
Is this possible on the 2007 3.6?
I do know how to get to the hidden menu 753(edited) from the home screen, it is not that diagnostic screen I am looking for. The one I need is where you can monitor connectivity to the GPS satellites.
I've bought a cheap KAKRA antenna to test out as I suspect the aerial may have filed after a heavy handed LR technician took it off to repaint my roof. However, it would be good to see how the satellite connections come on line with the replacement aerial and the roof based ones. For almost six months it worked fine, then afer the paint work it used to take about an hour to connect, now it is even less reliable.
Any ideas on how to get to this screen?
Thanks
Mark
Post #501209 11th Jan 2019 1:33pm
try code 753 for the sat screen..
Post #501214 11th Jan 2019 2:15pm
uzp315
Hi Stan,
Mm.. I think I might have meant 753 not 357.
So does the 753 work from within the sat nav screen as well as the home screen? Sounds easy enough. Do I have tp hold my finger on the top of the screen for 5 seconds like I would do if accessing the diagnostics from the home?
Post #501215 11th Jan 2019 2:19pm
i just searched the forum and it came up with this code...
Post #501218 11th Jan 2019 2:39pm
uzp315
Ok, thanks Stan.
I think they are the same diagnostic screens I am aware of. Alas, I haven't seen any sat nav diagnostics in those screens, but I did see in another thread a long time ago that someone has accessed a sat nav screen where they could see the status of the satellite connections - this is what i am trying to find.
Post #501220 11th Jan 2019 3:04pm
sorry i had to go and do something..
is this the thread,
https://www.fullfatrr.com/forum/topic17777...satellites
Post #501221 11th Jan 2019 3:34pm
uzp315
Hi Stan,
no need for an apology at all, I really appreciate your help. Yes that was the thread Smile Thanks.
From reading the thread it sounds like the satellite status screen is accessible by the 753. I haven't seen any satellite/gps status option on my 753 accessed from home screen by placing a finger in the middle top for 5 secs, then pressing the nav button 5 secs and then 753.
I dont suppose you know if this is the same diagnostic screen or is there another one and another way to get to the sat nav satellite status?
Post #501223 11th Jan 2019 4:00pm
others on that linked thread seem to have found it so i'd have another look and see if you have missed it.. Wink
Post #501226 11th Jan 2019 4:41pm
uzp315
Ok, thanks for the pointer. Saturday morning's first job
Post #501238 11th Jan 2019 7:38pm
uzp315
Nope, cannot see any sat nav diagnostics anywhere in the 753 screen. I'll take a pic and upload it a little later.
Post #501271 12th Jan 2019 10:57am
uzp315
Morning,
None of the options seem to lead to a sat nav screen. Any ideas
Post #501272 12th Jan 2019 11:01am
m@ttsFF
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
http://www.fullfatrr.com/gallery/albums/us...gnosis.pdf
Need to be in the nav screen 4.2 SC - sold , now bought back
4.4 AdBlu Tractor - Stolen
Post #501273 12th Jan 2019 11:16am
uzp315
That looks the ticket. I'll go and have another look. Thanks Smile M@ttsff
Post #501281 12th Jan 2019 1:06pm
uzp315
Well, I think it is probably a duff aerial causing my issues.
I had upto 5 satellites showing a "T" status meaning "Data is being received from an applicable satellite but is not being used for positioning" at one time, and eventually got three "P" status ("Data is being received from an applicable satellite and used for positioning. "). Signal levels never went about 22 which suggest poor reception, which suggests a compromised antenna.
£4 FAKRA GPS aerial ordered from the web to finally prove the theory one way or another, and then maybe back to LR dealer with a frowny upseide down face.
Many thanks everyone.
Post #501313 12th Jan 2019 5:24pm
Weegie
Have you tried moving your position and/or vehicle orientation? John
GAP iiD BT-Sold
Post #501318 12th Jan 2019 6:05pm
