![]() | Home > Technical (L322) > FBH operation with timed climate |
Pfazz Member Since: 07 Apr 2012 Location: Stalybridge, Cheshire. Posts: 507 ![]() ![]() |
Ah that makes more sense now, thanks. Agueroooooooooo. 93-20
G6 ROO Member Since: 02 Aug 2021 Location: Skipton, North Yorkshire Posts: 6 ![]() ![]() ![]() |
Just found this thread as recently bought a 2012 TDV8 and came to use the FBH for the first time this weekend and no joy from either Timed, Manual, or Fob operation (no evidence of anything ticking, clicking or whirring). Before I start stripping it down I was wondering how to check the software version and get it upgraded ? Did the Main Dealer do it for you and what am I asking for if I do the same ? An IID tool is on its way to me so I'll be checking for codes and attempting a reset as well as checking battery voltage. Failing that I'll be back on the forum ! Thanks |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 306 ![]() ![]() ![]() |
Is anyone able to say more about the software update for the FBH mentioned above. I have the same issues, including the IID E7 fault, as described at the start of this thread and would like to get the update if it’s available. TDV8 4.4 2012 |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
I’m getting E3 when I try to prime the unit and also test it 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
Mfcetin Member Since: 26 Jun 2023 Location: Nürnberg Posts: 69 ![]() ![]() ![]() |
I have another issue with FBH. I dont have the remote fob yet so I wanted to try the manual and time options to start the FBh. I can set a time and it comes on and seems to be working . After 3-4 minutes its blowing warm air to the windshield.
kokamagi Member Since: 31 May 2020 Location: Viljandi Posts: 84 ![]() ![]() ![]() |
Yes,
