Home > Maintenance & Mods (L405) > L405 Timed climate retrofit
aljo
United Kingdom 2019 Range Rover Vogue SE 2.0 PHEV Santorini Black
Hi All
Just wondering if it is possible to fit timed climate and remote park heat as a retrofit ? my 2016 L405 does not have this fitted from the factory
and if so what parts would be needed
Allan Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
Post #502131 19th Jan 2019 5:38pm
Hairy Dan
United Kingdom 2014 Range Rover Vogue SE SDV8 Luxor
Hi aljo, have a read of this thread
https://www.fullfatrr.com/forum/topic49671.html
You can't retrofit remote fbh but you can enable timed climate although as mentioned in the thread you will have an error in the system but timed climate does operate as designed. Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #502170 19th Jan 2019 10:36pm
Hairy Dan
Sorry I copied the wrong thread url in it should be this one
https://www.fullfatrr.com/forum/topic48127.html Cheers Ian
Kielder 4x4 Safari
Post #502172 19th Jan 2019 10:39pm
aljo
cheers dan Thumbs Up
seems a pity that you cant enable the timed climate and park heat and fit a reciever and remote fob like i did on my old rrs Big Cry
the car has practilly every conceviable extra toy but no timed climate and remote park heat Big Cry Big Cry Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
Post #502174 19th Jan 2019 10:44pm
Hairy Dan
I know, it's the one thing I miss from my Disco 4's. Being retired I don't go out at the same time every day so I have to remember to set the timer the night before if I'm going out early and it would be so much easier to just press a button Crying or Very sad Cheers Ian
Kielder 4x4 Safari
Post #502177 19th Jan 2019 11:04pm
charlie croker mk2
Do you have the "in control" app on your phone ? in very cold weather the car only needs about 5 to 8 mins to get quite warm inside but you do have to remember to use it !
Post #502231 20th Jan 2019 7:05pm
aljo
hi charlie
Yes I do have the incontrol apps but no remote engine start Big Cry Big Cry
is that something that could be added to incontrol apps or would it be a major dealer only job on the car ? Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
Post #502232 20th Jan 2019 7:20pm
charlie croker mk2
Its not remote engine start its diesel burning heater start up , I thought that your 2016 car would have had this ( mine is September 2015 and has this fitted ) but I suppose this is why you started the thread in the firs place !
Post #502235 20th Jan 2019 7:28pm
aljo
the topix build sheet states "less park heating" and "less block heater"
it states it has a fbh but no mention of "timed climate" fitted or not Big Cry Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
Post #502236 20th Jan 2019 7:39pm
