Home > Technical (L322) > PCV and Vacuum System problems |
tony66 Member Since: 01 Dec 2014 Location: fife Posts: 92 |
maf is simple-check live values match what are asked for....pcv would be first port of call as its a job that needs doing anyway |
20th Jan 2019 3:07pm |
crowebeard Member Since: 19 Dec 2016 Location: Devon Posts: 93 |
Thanks Tony66 - MAF readings appear to be around normal (although perhaps little low at idle) so will concentrate on PCV hose replacement. David
21st Jan 2019 2:34pm |
remember issues such as egr control etc effect maf readings too
23rd Jan 2019 12:42am |
As the weather was so good today, I finally got around to fitting the new top breather hose on the PCV unit that @duckworthparts kindly sent last week, but while I was digging around the back of the engine I found a couple of additional problems that may be causing the occasional lumpy running.
14th Feb 2019 9:24pm |
