Home > Technical (L322) > Emulsified diesel fuel in injector rail and filter
Pete Broom
Hi - Anybody come across this - we're a repairer and we have a car in that was experiencing severe diesel knock and some over revving when driven under load or revved up in workshop. We found grey gunge/some emulsification of the diesel in the injector rail when we inspected and renewed the pressure sensor. Renewal of the sensor has fixed the sympton (the knock and over revving) but we cannot explain the emulsification. We were thinking that perhaps the diesel could mix with the coolant in the FBH but felt this would be unlikely as the coolant would drip into the burner and out the exhaust - there would not be enough pressure to make the coolant enter the fuel system through the burner jet?
Post #502632 24th Jan 2019 12:52pm
CS
Might this be due to use of 'FAME' biodiesel which is hydroscopic, so source of water not the rail etc but in the tank? Q checking the rest if the system and asking where the customer sources the fuel. Only Range Rovers since 1988
Post #502660 24th Jan 2019 3:09pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
+1 for fuel contamination. Probably water in tank. Complete flush needed me thinks.
Let us know what you find. Good luck 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #502726 25th Jan 2019 12:24am
kooky_guy
United Kingdom 2010 Range Rover Vogue SE TDV8 Stornoway Grey
You won't get water into the fuel via the FBH as it's a separate fuel feed and I'm sure there isn't a fuel return to the tank. 2010 4.4 TDV8 Vogue SE
Post #502736 25th Jan 2019 7:39am
Pete Broom
Source of fuel varies so no common link there. Have flushed pipework and sent him on his way with a new rail pressure sensor and a bottle of Wynns biocide to help break down any bacterial presence. Probably should have added some Wynns Dry fuel and also sucked tank clean but the labour content on some jobs just isn't fully justified for some peoples budgets???? Thumbs Up
Post #503185 29th Jan 2019 12:24pm
