Home > Technical (L322) > Engine Heating up
VMPP
Portugal 2007 Range Rover Vogue TDV8 Buckingham Blue
Engine Heating up
Hi all
Every journey that i make ends up with the radiator fan under emergency mode.
Yesterday the engine started heating up, not to the red, but like midway right of middle, even though there are no visible coolant leaks or anything else.
Water pump is ok, radiator was replaced together with the water pump, so... nothing to go wrong or so it seems.
When I parked, I checked the reservoir, and when I opened it, it released the pressure and water was like boiling, going blebeleblebelbelbeleblebelebl...
What am I looking at? Thermostat stuck? other thing?
Post #502770 25th Jan 2019 5:34pm
CS
Suggest check if air lock in system preventing coolant circulating and bleed system of air as necessary. Only Range Rovers since 1988
Post #502777 25th Jan 2019 7:14pm
