![]() | Home > In Car Electronics (L322) > Static on all radio channels |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35831 ![]() ![]() |
this shows where the antennas are..
Gyre8 Member Since: 14 May 2017 Location: Wolverhampton Posts: 259 ![]() ![]() ![]() |
Thanks Stan. Very useful.
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
When i charge my phone in car using a usb adapter in the aux plug i get static on the radio pull it out and it goes back to a perfect signal,a bit annoying but just put spotify on instead. _____________________________________________________
@Scottyav. Nothing plugged in to AUX. However today no static on radio channels, but I did get the 'Transmission Fault - Traction Reduced' message on startup.
Stormin Member Since: 22 Feb 2012 Location: West Yorkshire Posts: 266 ![]() ![]() |
I have had the same problem, mine was caused by the coat I was wearing. If the problem occurs, I exit the car close the door. remove said coat and get back in. works every time.
Hmm. OK. I'll try driving around in the nip to rule out clothing related issues. What could go wrong? |
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1100 ![]() ![]() ![]() |
You could get a flat and have to change a wheel -- still look on the bright side -- it'd be a place to park your bike :O Current: 2011 FFRR Vogue SE 4.4 TDV8
