![]() | Home > Technical (L322) > Help identifying a piece of trim |
RRV78 Member Since: 15 Sep 2016 Location: Truro Posts: 203 ![]() ![]() ![]() |
To me it’s the rubber trim that fits on the tailgate glass.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7996 ![]() ![]() ![]() |
That’s the only thing that came to my mind too. Supposed to stop water dripping on the parcel shelf when you open the tailgate and the window is wet.... 2011 Range Rover Vogue SE 4.4 TDV8
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1198 ![]() ![]() ![]() |
^^ I'm with the above.
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2719 ![]() ![]() ![]() |
That’s exactly what it is, did the pair of mine PITA job! |
topgeartowers Member Since: 23 Mar 2010 Location: London Posts: 83 ![]() |
Thanks lads! Love this forum. |
How come you removed them? |
They look like they just slot on? Maybe some adhesive at the top to hold it? What did you have to do? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35841 ![]() ![]() |
oters have removed the trims because of the common corrosion at the bottom end...new ones slide back on, a bit fiddly but not that difficult.. |
I just pulled mine off they were corroded and bubbling at the bottom. Current: 16 my2016 Range Rover l405 4.4 sdv8 Aruba gold & 11 MY2011 RANGE ROVER L322 4.4 TDV8 ZERMATT SILVER
