![]() | Home > Maintenance & Mods (L322) > Speedometer accuracy question. |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 713 ![]() ![]() ![]() |
Has someone fitted undersize tyres to the car ? Paul,
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35850 ![]() ![]() |
i wouldnt take for granted that the 'road speedo' readouts are that accurate...get an aftermarket gps that shows the mph.. |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1198 ![]() ![]() ![]() |
Your car speedo is not necessarily reading the actual road speed. As Pawl and Stan say, tyres and sign accuracy come into it. I found this bit some time ago which seems to indicate that the regs give some leeway to overreading, but do not allow the speedo to under read. Again, that will depend on the tyres and anything else the manufaturer uses in their design.
Busterbulldog Member Since: 23 Oct 2015 Location: Caerphilly Posts: 7 ![]() ![]() ![]() |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
I had that size on my 2007vse and my 2011vse and the speedo was very accurate according to the App i use ( Speedometer) Also road side speed warning signs that i pass everyday agree with the App |
Nick591 Member Since: 04 May 2017 Location: Seaton Dalaval Posts: 193 ![]() ![]() |
My 2008MY 3.6TDV8 on 255/55/20 Wheels and tyres reads about 2 to 3 mph under true speed. Thus at 50mph on my Sygic satnav the speedo is showing around 52. Same difference at 30 and 70. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8 |
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 ![]() ![]() ![]() |
Switched to 22" wheels from 20's.
So it's likely these are non original wheels and it needs an adjustment then via someone with the correct equipment ? |
you need to have a look at what's on first and go from there....post a pic or the size .. |
All posted above |
Sorry, that's not what I meant. Using the IID Tool you can check - and change if necessary - the settings your speedo uses to calculate your speed. What do I put here then? |
What is this tool I need and where would I find it and how much will it cost ? Or should I just book into a dealer for adjustment ? |
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1102 ![]() ![]() ![]() |
Buster,
