Home > Technical (L322) > oil in intercooler pipe
iancollins
England 2016 Range Rover Vogue SDV6 Causeway Grey
just noticed when checking fluid levels this weekend that there was oily deposits around both ends of the pipe that goes from the intercoller pipes (both sides) to the turbo..
is this correct or is the turbo on the way out ???
has anyone else noticed this ??
it's not clear oil but looks like when you have had an engine oil leak and it gets mixed with grime..
Post #53275 7th Mar 2011 11:17am
if its only a little oil then its probably from the crankcase breather, if it was runny and you had a lot there then it would be worn bearings in the turbo...a little mucky oil deposit is normal.. ... - .- -.
Post #53280 7th Mar 2011 11:33am
iancollins
thanks for the response..
maybe i'm being a bit paranoid but oil in intercooler pipes = ££££££££
thanks for the piece of mind
Post #53337 7th Mar 2011 3:54pm
i'd still keep an eye on it though ian... ... - .- -.
Post #53346 7th Mar 2011 4:29pm
iancollins
thanks for your reply.....
surprised no one else has put their "penniesworth" in though....
thought it would be of interest to other members as turbo failure (oil seals) is not uncommon on TDI cars and bloody expensive to repair Shocked
Post #53477 8th Mar 2011 11:09am
arron
United Kingdom 2005 Range Rover Vogue Td6 Java Black
well heres my little bit then, i have never seen a td without oil in it intercooler pipes yet and i been a mechanic for 20 years. the breather system vents into the inlet which carrys oil with fumes so it gonna get in there no matter what unless you vent the system, it does build up and cause the intercooler to become Inefficient. there supposed to be cleaned out anualy but no one bothers, if there was a problem with your turbo causing it they tend to run on there own oil and rev there little bits off untill you find a way to stop it or it seizes up when its used all the oil out the sump. take a while using two gallons though. Big Cry
Post #53603 9th Mar 2011 12:20am
