Home > Technical (L322) > Electrical gremlins in window
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
2003 M62 V8 L322. This is either a simple fix that someone will know about or so complicated to find it isn't worth the bother! When you operate the rear window locking switch on the drivers door (to unlock position), the rear nearside window goes down of its own accord. It then will not respond to any of the ordinary window operating switches. It will only work if you re-lock the lock switch and operate the normal lift switch on the drivers door. Any ideas? Could smiply be a faulty lock switch I guess, all suggestions gratefully received. Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #505433 17th Feb 2019 9:29am
that switch panel does get wet easily so i would take it out and have a look at the connections for oxidation..other than that , replace it. .
Post #505438 17th Feb 2019 10:08am
rvbush
Thanks Stan, at least that's an easy thing to look at! I'll check it out. Drives:
Post #505535 18th Feb 2019 8:55am
