Home > Technical (L322) > Access mode annoying gremlin
dazza1983
United Kingdom 2011 Range Rover Vogue 4.4 V8 Santorini Black
So annoying little fault possibly. When I press the button for access mode it starts to lower then says suspension in extended mode please reselect.
Then if I press a second time it’s ok 99% of the time anyway.
Also 99% Time if I press access mode whilst driving slowly it works first off.
Annoying problem but I’d love to get it sorted.
Post #505847 20th Feb 2019 10:12pm
RJH
England 2011 Range Rover Vogue TDV8 Santorini Black
Had the same issue, not sure on exact fault but if you have a warranty then possibly covered.
Mine was sorted by the dealers.
Rob. 2011 (MY12) 4.4 TDV8 Vogue
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #505849 20th Feb 2019 10:20pm
bishbosh10
I had this problem that got progressively worse. It is because the exhaust filter for the suspension compressor is getting clogged with age.
When you ask it to lower if it doesn't lower quickly enough for the car's liking it thinks it has grounded on an obstruction and so goes into extended mode.
The good news is that it is a very easy fix - open the boot and remove the spare wheel and then the cover over the compressor. You will see the filter - it is a conical brass object with a hex at the compressor end. Remove this and drill a small (2mm is plenty) hole in the end of the filter. Refit and all should be well.
Alternatively, buy a new filter if you like spending money! Very Happy Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #506308 25th Feb 2019 2:11pm
dazza1983
Thanks for the reply buddy.
I’ll deffo check that out.
Don’t suppose you have pics or links or anything. Never even seen the compressor. So not sure what I’m looking for.
Daz
Post #506310 25th Feb 2019 2:16pm
this ,from our wiki, will help,
https://www.fullfatrr.com/forum/topic23038.html
Post #506313 25th Feb 2019 2:35pm
dazza1983
Many thanks
Post #506314 25th Feb 2019 2:37pm
dazza1983
HMM... Turns out the silencer is not avaliable on its own anymore?
Any ideas?
Guess i could try the suspension with the silencer out and if it works ok i could try cleaning the origional?
Daz
Post #506333 25th Feb 2019 4:24pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Try it with it out, you'll know if that's the issue then Smile Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #506334 25th Feb 2019 4:25pm
^ what bushy says and if it works then drill that hole..
Post #506340 25th Feb 2019 5:36pm
