Home > Maintenance & Mods (L322) > 3 button key refurb
Balloonengineer
3 button key refurb
Hi All
I have just changed the rubber buttons with this pad off ebay
https://www.ebay.co.uk/itm/223398533195?Vi...3398533195
It actually works very well.
Its easy to fit with a watchmakers flat screwdriver to pry the rubber over the case lips, but removing the original is quite tricky if you plan to save it as it appears to have been moulded in place when made, it has fingers of rubber that go through tiny slots. Again the small flat blade screwdriver worked best to tear away the rubber from the case. If you don't want to save it, then just tear it away.
Best wishes
Glen Previously......
Series 1 80, Series 3 88, Turbo 90, 300tdi 90, 110's with 200, 300, TD5
TD5 Disco, Disco 3, 200Tdi Disco - probably the best vehicle Landrover ever made,
Now 3x FFRR, some would say I should have learned by now......
Post #506150 23rd Feb 2019 11:21pm
Post #506161 24th Feb 2019 9:03am
Discotigger
Hi,
I've used this guy a few times, the rubber pads are really good quality (quite good price too) and easy to fit. Just make sure you don't lose the transponder chip when you're changing the rubber pad though, as someone I know managed to do with almost disastrous consequences, till I managed to find it for him and refitted it.
I've done both my keys and got some pads for my local indy garage to use on customer cars, as well as sorting a few friends key fobs as well.
Can highly recommend this guy.
Post #506304 25th Feb 2019 1:40pm
crowebeard
United Kingdom 2012 Range Rover Westminster 4.4 V8 Orkney Grey
Great find Glen.
Key looks like new again. Thumbs Up David
2012 Range Rover Westminster 4.4TDV8
2004 Range Rover Vogue 4.4 V8 (LPG) (Not quite gone)
2021 Mazda CX-5
2003 Porsche Boxster
Post #506848 1st Mar 2019 2:03pm
Swipe
United Kingdom 2004 Range Rover Autobiography Td6 Java Black
Ordered the new rubbers so hopefully it’ll take the key back to new.
Post #506904 1st Mar 2019 6:45pm
Balloonengineer
Thumbs Up Previously......
Post #506915 1st Mar 2019 7:57pm
Swipe
Changed the pads today nice easy job key fob looks much better.
Only problem i’ve Got now is the key isn’t opening the car, can start the car but won’t lock or unlock.
Tried to re-sync it but still can’t get it to work, have to lock and unlock with my spare key.
Will try again tmw if I have time, will be ordering another key fob rubbers for my spare soon. 2004 Autobiography TD6 Java Black
Post #508220 10th Mar 2019 8:04pm
