![]() | Home > Maintenance & Mods (L322) > Drivers seat switch surround panel |
BMG Member Since: 26 Feb 2019 Location: Kent Posts: 196 ![]() ![]() ![]() |
The dull chrome like film on the drivers seat switch surround panel is lifting off. Is is possible to sperate this part from the rest and replicate the chrome like finish ?
Jsteed Member Since: 14 Feb 2019 Location: Uk Posts: 2 ![]() ![]() |
Hi, yes the chrome trim is removable. I have the same problem.
Cheers. Think I'll take a chance on the AliExpress stuff and see how it goes. |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
Looks like your seat foam has failed which means you are now flexing the chrome trim and this lead to the chrome finish delaminating, your new trim will do the same and eventually crack if you don’t replace the Lower seat foam. |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 570 ![]() ![]() ![]() |
I would agree with what ur20v says. I'm surprised that the side panel is still attached. But changing the foam I assume would be a PITA (excuse the pun) anyhow. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16398 ![]() ![]() ![]() |
An easy non expensive fix would be to take the two front seats out and change the seat base's over... The outside of both will then be like new |
This is the passenger seat, which doesn't look that worn next the drivers side.
Those Aliexpress parts look great for the price! I look forward to hearing how you get on with fitting them. I'm sure they will fit fine.
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
Hi, Price for seat base from Duckworths £94 filler part £38 this is for a 2011 year |
