![]() | Home > Technical (L322) > Low coolant sensor |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3880 ![]() ![]() ![]() |
Have you got the right mix of antifreeze in.
edward19 Member Since: 11 Feb 2019 Location: South Coast Posts: 55 ![]() ![]() ![]() |
Ah well. I just stuck in water to top it up. it didn't seem low even before I had to remove some coolant pipes!!!. So you think I should drain and refil with the right coolant and see what happens? |
Our friend Nino-Nino found this out the hard way when he filled his with water and got the low level warning.
The antifreeze looked pretty brown so I will drain it all out and refil. Hopefully the message will vanish. Thanks for the suggestion. |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
Edvard, this is how I did on mine
2012 TDV8 Black Edition 2000 Disco. TD5 1975 series III |
