Home > Technical (L322) > Tensioner Pulley removal options on a 4.4 TDV8
edward19
United Kingdom 2011 Range Rover Vogue 4.4 V8 Santorini Black
Hi All
Although this topic has been covered before I'm trying to decide what to do about my pulley / belt noise. The belt looks ok but it does not sit true on the main tensioner LR02289. When I put it back on the tensioner the moment you crank the car it slips 1/2 off. Would I be right in thinking that a tensioner change should solve it. I'm hoping to do this one without removing the fan and shroud. Does anyone know if this is possible.
Thanks
Post #507360 4th Mar 2019 8:55pm
matthews
United Kingdom 2011 Range Rover Vogue TDV8 Buckingham Blue
A bit fiddly but 1/2 hour job with boost hose removed , be careful with the little coolant pipe as it's easy to snap , did mine just before xmas for this very reason , don't wear thick jumpers !.
Post #507886 7th Mar 2019 10:43pm
Did mine.
https://www.fullfatrr.com/forum/topic48934.html
Not too bad a job, get it done before it goes or then it’s a belt replacement too which is a lot more involved. There is nothing that can't be fixed with a hammer😜😜
Post #507892 7th Mar 2019 11:21pm
edward19
Thanks for the advice. The worst bit was putting the blasted tensioner bolts back in. I had to visit landrover as I dropped two and couldn't find them!!!
Post #507979 8th Mar 2019 3:43pm
