Home > Technical (L322) > One touch window lift
Andy
I don’t have one touch window lift and I can’t find it in the IID to install it. Can anyone point me in the right direction ?
Post #507658 6th Mar 2019 7:54pm
rjff
On the driver's door:
Open the window with the switch. Release, hold switch down for a few seconds.
Close the window with the switch. Release, hold the switch up for a few seconds.
Repeat for each window.
You've had the battery off recently???? Cheers
Richard
Gap IIDBT
Post #507668 6th Mar 2019 8:35pm
Andy
It didn’t work when I bought it.
I have had the battery off yes. I tried to fit the 110aH but it didn’t fit!
I’ll try that trick. Thanks
Post #507675 6th Mar 2019 9:01pm
Andy
Ok- tried that. Didn’t work!
Post #507683 6th Mar 2019 9:22pm
rjff
Sorry about that. I'm not sure if your model has the same switches as mine, two clicks when pushing or pulling. Maybe a subtle difference in model years.
I can't look at mine as she's in for a little paint, but I'll have a look at the GAP when she's back to see if I can find anything to help.
Perhaps in the meantime someone with a bit more nous will be along. Cheers
Richard
Gap IIDBT
Post #507703 6th Mar 2019 11:19pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Try engine running and all four doors closed. Open the drivers window first and hold the button down without releasing it, hold it down for about 10 seconds and you should hear the relay reset itself with a soft click. If that doesn’t work try holding it down for a bit longer. Then repeat in the opposite direction to set the window close function, if that works do the same for the other windows.
The sunroof has to be held in the tilt position on the button for longer, something like twenty or so seconds to set the auto close / open function.
Hope this works, it does for me Thumbs Up ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #507711 7th Mar 2019 12:31am
Andy
It’s only the drivers door that does it. All the other windows are ok.
@rjff - It is s two stage button as well same as yours .
Post #507718 7th Mar 2019 7:51am
rjff
Andy
Yes mine is a two stage button. I seem to recall seeing somewhere on here a post about this. IIRC some corrosion had ocurred in the door switch. Perhaps a little water ingress when the window was open and/or the washers used. I know it sounds a long shot, but I'll see if I can find it agin.
In the meantime, I see you've posted in General about being a bit unhappy with things at the moment. How's about putting up all the bits concerning you and I'm sure all on here will try to help.
Oh, could you also update us on the model year and other details on your car. I assume it's a 2011 TDV8 with the 8 speed box. Thumbs Up
Just found your details in another thread, ignore last comment. Smile Cheers
Richard
Gap IIDBT
Post #507733 7th Mar 2019 9:38am
p38arover
Australia
I used Faultmate to change mine. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #507752 7th Mar 2019 11:33am
