![]() | Home > Maintenance & Mods (L322) > Best way to jack one side of the FF |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2621 ![]() ![]() |
Opening doors, putting hazard lights on etc. does nothing - hence why it’s not mentioned in the handbook. |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 546 ![]() ![]() ![]() |
That's not true. Opening a door interrupts a suspension height change for safety reasons. It may not prevent adjustments but it stops a change between access / standard / exetended height. It even shows up on the info display when it happens. 2016 Skoda Octavia VRS Estate
It used to be the tailgate as well as any doors on the P38A - I believe the hazard warning lights were simply that:
Maybe not for just changing a wheel. But anytime a part of me is going to go between a sprung piece of the FF and an unsprung piece (or anything else that's fixed), I do it. Anything that easy to do that might prevent a height change seems worthwhile to me. 2016 Skoda Octavia VRS Estate
Fraynizzle Member Since: 27 Apr 2015 Location: Essex Posts: 111 ![]() ![]() ![]() |
the manual only mentions jacking to lift the body, using jacking points and subframes not suspension arms.
from the workshop manual regarding air suspension inhibit modes, make of it what you will.
jakebullet64 Member Since: 28 May 2014 Location: Wolverhampton Posts: 259 ![]() ![]() ![]() |
Believe me. Being under the fatty and forgetting to leave a door open, then hearing the eas valves start to adjust the height is a code brown moment!!! 2003 Range Rover Vogue 4.4 on Gas
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 508 ![]() ![]() ![]() |
Been there, done it, never moved so fast, a very unsettling sound |
can you explain what state the car was in when the adjustment started?
Done when I was replacing all brake pipes,
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 527 ![]() ![]() ![]() |
Maybe not the same, but I jacked my Disco 4 up at the weekend.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35814 ![]() ![]() |
this extract from the WM explains how to jack up the FF,
