Home > In Car Electronics (L322) > Key transponder
Henda
United Kingdom 2006 Range Rover Vogue TDV8 Zambezi Silver
Key transponder
So I have my new bt tool and I need a spare key
So I've looked at my key
Mine is a late 2006 in dash ignition
So it's a 3 button key
I think it's 433 MHz
And I've looked it's a pcf7936as transponder, which I think is id 46
But the next 2 lines read
D8ye00039
Dn06370
I've looked on flea bay and I can find id46 and pcf7936as
But I can't match the other two lines any ideas out there and is this the reason 06/09 models are hard to pair with new keys
Cheers Thumbs Up
Post #508011 8th Mar 2019 7:58pm
dingg1
I tried along with a guy from south africa who had access to other key programmers and we gave up trying to code new keys to a 2007 car
If you manage to do it please let me know as I could do with a spare.
Good luck and try not to tear your hair out Confused
Post #508021 8th Mar 2019 9:59pm
Henda
You can get transponders for coppers but the numbers are different
I think my 2006/07 some may have the old type and some the new type transponders
They mite run on different MHz
Think I will start with a key to try to get it to work with the central locking
Then try and get a chip that works
A lot of the fleabay ones are for Peugeot cars and I think the 3.6 is a Ford/ Peugeot lump
It sounds so easy on the I'd tool
Bcm- yes
Program keys - yes
Then I think it's insert key and repeat
Rolling with laughter Rolling with laughter I wish Thumbs Up
Post #508056 9th Mar 2019 10:21am
Henda
Dingg1 hello mate did you use the idd tool and a new transponder chip
I think genuine chips are made by Siemens so that's maybe the route to take Thumbs Up
Post #508059 9th Mar 2019 10:27am
dingg1
Hi Henda
We used hooky keys from china with the correct chip in each case , the guy has a chip reader and confirmed it was correct , I had no luck at all with the iid tool and asked on all forums if anyone has been able to manage it , it appears no one has.
He used a k900 (iirc) and had no joy and he has managed in all other variants of range rover but not a 2007/8
Hth
Post #508063 9th Mar 2019 10:54am
Henda
Sounds like a pill to do
May as well give it a go you never know Rolling with laughter Rolling with laughter
Post #508066 9th Mar 2019 11:17am
