![]() | Home > Technical (L322) > Distorted rear camber settings? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6428 ![]() ![]() |
Could be just alignment, but more likely a worn out upper or lower or both hub joints, or the toe arm.
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 508 ![]() ![]() ![]() |
My money is on the wheel having too much toe-in, ie toe arm ball joint worn or securing cam bolt has moved. |
PIMCO Member Since: 30 Jul 2018 Location: Oslo Posts: 44 ![]() ![]() |
Thanks for he input.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
Just replace the whole lot. What I did. New rod, bolts etc etc
Hmm, does this look right (keep in mind suspension is at full drop)?
The rubber is shot to pieces on the right (in your photo) but the only way to tell is to get the weight off it and see if it wiggles (easily...) if it does, replace.
That looks proper |
TomCobbly Member Since: 29 Jun 2016 Location: Guildford Posts: 124 ![]() ![]() ![]() |
Looks like the wishbone is bent due to the corosion |
I agree it does not look pretty - but it's primarily surface rust and the A-arm has that kink built-in already, right? |
Can anyone confirm bolt/nut size on the tie-rod/tie control arm? It's hard to tell for sure with the corrosion and what not, but the best fit seems like 18mm and 20mm, but it's loose enough to where I think it could be imperial (referring to the bushing side)? Is the nut toward the front of the car welded/fixed, or is it an independent through bolt/nut?
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 713 ![]() ![]() ![]() |
Definitely all metric. 18 & 20 mm sounds right from when I did ours.
I had to grid/hacksaw my 10mm nut off the toe arm, whole thing just going round and round. OK if replacing the whole thing.
