![]() | Home > In Car Electronics (L322) > L322 2004 DSP disappeared FIXED |
MadL322 Member Since: 10 Oct 2018 Location: Yeovil Posts: 108 ![]() ![]() ![]() |
If the DSP has failed, have one for sale at the moment if you're in need |
SilverParrot Member Since: 09 Aug 2018 Location: Herts Posts: 25 ![]() ![]() ![]() |
Will keep it in mind Thanks,
if you need anything else, I have all the audio kit from the rear, took it out at the weekend in prep for a new head unit so all parts available. |
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1100 ![]() ![]() ![]() |
Open up the DSP, mine had funk on the inside, and a disconnected pin! Current: 2011 FFRR Vogue SE 4.4 TDV8
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7993 ![]() ![]() ![]() |
It will be grey in the menu until it identifies itself on the ibus, then it will be white again.
Thanks mjdronfield |
Nice one.
