Home > Technical (L322) > Flashing brake lights
cheezels
Australia 2007 Range Rover Vogue TDV8 Java Black
I’m not sure if this is a new issue............but I just noticed that when I switch the ignition on the brake lights “flicker” on and off for 16 times.
Only happens when starting her up.
Odd or normal Laughing 2007 3.6 TDV8
Post #509510 22nd Mar 2019 6:07am
gj88
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Normal if you've upgraded your lights, they do a check on start-up. You can turn it off with the IID tool. Assume it's that?
Post #509521 22nd Mar 2019 10:10am
I have the 2010+ rear lights, with all hot and cold monitoring turned off (no gizmo attached).
They still do some very fast blinking on startup (brake lights), but, sides, indicators and brake lights operate normally in every other way .
Post #509539 22nd Mar 2019 12:45pm
cheezels
I’m not sure the hot or cold monitoring should cause the lights to flash, if they’re standard?
Also, wouldn’t they flash continuously whilst the ignition is on? Or does the “monitoring” stop after a certain time.
Might mess about with IID tool and see if disabling the monitoring does anything.
Tis a bit weird 2007 3.6 TDV8
Post #509549 22nd Mar 2019 1:54pm
gj88
Bit weird if all standard, the monitoring does stop after a few flashes. I changed my reverse lights to LED bulbs and then had to turn the monitoring off using the IID. Worth a look either way
Post #509553 22nd Mar 2019 2:25pm
