Home > For Sale & Wanted > Solar powered battery conditioners
claud
United Kingdom 2018 Range Rover Autobiography TDV6 Corris Grey
Bought one, will plug it in rear boot cigarette lighter which is permanent live. 2018 Range Rover Autobiography
2010 Land Rover Freelander XS
1959 Series II
1950, 1952, 1954. 1955, 1957 Series I
1952 Minerva Ambulance
Post #59580 9th Apr 2011 5:51pm
dantheman
Top notch - bought one the other week. Ideal for the bike too!
Post #59608 9th Apr 2011 11:49pm
AMV
2011 Range Rover Vogue TDV8 Santorini Black
Guys, will this work with 2011 cars? Question Santorini Black RR Vogue 4.4 TDV8
Post #60088 12th Apr 2011 7:34pm
johnson1
No, don't think so as all the power switches off with locking (even the one in the boot which was previously always live). Tbh, I think it's pretty bad that a new owner is having to consider one of these - cars should be able to sit unused for weeks and start fine.
Post #60146 13th Apr 2011 9:52am
Havank
United Kingdom 2003 Range Rover Vogue Td6 Java Black
I bought one about 4 years ago, when I had the issue of a dead battery every other day (FSR was still a big issues back then)
I even bought an overload protector.
AND ITS USELESS TOTAL WAIST OF YOUR MONEY - sorry -
If it drains it will drain, and nothing can stop it Big Cry Big Cry .
Best to find the reason why it drains, and then fix it
I fixed 4 years ago the FSR and since then it was fine (fingers crossed) so i have one solar panel and an overload protector laying arround in the car Whistle
Post #60173 13th Apr 2011 4:48pm
AMV
Well, that sucks. I've heared so many stories about flat dead batteries so I'm getting ready Very Happy Santorini Black RR Vogue 4.4 TDV8
Post #62650 4th May 2011 8:04pm
Sorry but simply not true,
I use the Maplin Solar charger on my stock Range Rovers and it it works a treat with NO failed starts since I started using them.
HIGHLY recommended from a multiple user. Thumbs Up
Post #62658 4th May 2011 9:03pm
Vogue
agree with Gaz, these solar chargers will prevent low level discharge from causing a flat battery. What they will not prevent / overcome though is a fault which flattens a battery over a couple of days. The output of these panels is not sufficient to counter high level discharge.
If your RR battery goes flat over 1 to 2 weeks, they will just maintain it. If it goes flat overnight though you need to sort the discharge issue. These chargers will charge a flat battery BUT due to the low output it will take 1 to 2 months to charge a flat battery depending on battery capacity and load demands from alarms and other electrical draw and discharge.
Post #62672 4th May 2011 9:56pm
AMV
Are you sure? The manual says it is always working Rolling Eyes Santorini Black RR Vogue 4.4 TDV8
Post #68366 13th Jun 2011 10:52am
AMV
Quote:
Note: The rear loadspace socket is constantly
live. If an accessory remains attached while
ignition is off, battery drain may occur.
Only use Land Rover approved
accessories. Using any other
equipment may damage the vehicle's
electrical system. If you are in any
doubt contact a Land Rover Dealer/
Authorised Repairer.
The engine should be running when
using accessories for long periods.
Failure to do so can discharge the
battery.
Note: Power sockets can be used to power
approved accessories that use a maximum of
180 Watts.
Post #68574 14th Jun 2011 7:54pm
DavidP
Belgium 2006 Range Rover Vogue Td6 Bonatti Grey
Hello, I am looking at getting one of these for long term parking.
Checking the Maplin website there are various available, from 1W throught to 4.8W.
Is one better than the other, ie higher wattage?.
Thanks in davance
David
Post #70087 27th Jun 2011 6:43am
