![]() | Home > Maintenance & Mods (L322) > I hour fight with td6 injector no5 |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
I started having tick over issues after running the car hard so a bit of diagnostics, pulling the injector plugs off one by one pointed at no 5. As I had a used good spare in the toolbox today I made the swap. Ist thing I tried was to loosen the injector clamp and run the engine to pop it out. Not a chance, this one was not giving up so out with the eBay slide hammer. I hour of waking, loads of wd40. I finally got it moving. putting sideways / rotational pressure whilst using the slide hammer. Once out, what a mess, the hole was full of hard carbon. I used a shop vac with a 1/2 in tube to get it out. The washer was still in the bottom and that took another 1/2 hour to dislodge. Replacement in, all back together and a test drive confirms all is well again.
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 ![]() ![]() ![]() |
Look at all that crud!
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 419 ![]() ![]() |
Looks like the copper sealing washer has failed hence the carbon up the side from combustion gases. It may have been suffering from lower compression on that cylinder and possibly a misfire if bad enough. The injector may actually be OK although if you had a good spare then it would be prudent to use it like you did.
The egr is blanked, I have done 55000klm in the car and did the blank as soon as I got it. The previous owner had work done on the head at a Dealers so they would have refitted that injector. 2007 TDV8 VSE 2003 TD6 gone. 2002 P38a gone 1999 P38a gone 1997 p38a gone 1993 VSE gone 1992 VSE gone 1966 Series 2a with V8 conversion gone |
