![]() | Home > Technical (L322) > Transfer box neutral message, suspect ECU |
clemenz Member Since: 13 Sep 2014 Location: Graz Posts: 183 ![]() ![]() ![]() |
Following with interest as i had the same problem. Refurbished shift motor solved the problem.
Judo Member Since: 24 Nov 2016 Location: Melbourne Posts: 14 ![]() ![]() |
Update...
If you get an occasional message, I would probably still be looking at the potentiometer in the shift motor assembly. If you've searched this you'll see you can't buy just the pot which is unfortunate, but if it gets worse you can cut it open and have a go at repairing it if you're a DIY type person... Also if I'm anything to go by, you should always check fault codes and perform troubleshooting 101 before cutting anything open!! -Justin 2006 Vogue Td6 |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6432 ![]() ![]() |
Plenty for sale on UK eBay:
Chris.Gr Member Since: 19 Apr 2019 Location: Kifissia Posts: 7 ![]() ![]() ![]() |
Any update cos have the same brb? |
brb ? (be right back) .
I found a workshop and parts supplier here that had a second hand ECU. They posted me an ECU and I tried fitting it just before Easter only to discover it doesn’t fit. Very similar but the sockets for wiring looms are in a different order on the ECU. The looms are basically an exact size from 2 different sides of the ECU housing so they don’t reach to the positions on my new ECU. Have to wait another few days until they’re open again and see about swapping it.
