![]() | Home > Technical (L322) > Engine oil service |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 419 ![]() ![]() |
Most likely forgotten about by the mechanic although the interval is 'condition' based rather than a fixed value so it's dependent on a few factors.
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 ![]() ![]() ![]() |
What year is your car and what engine?
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
If you are that far from an LR garage Then I strongly advise you to buy and keep an IID tool in your car You can check lights and reset your own service lights, also why wait for a light to tell you when to do something? preventive work will keep your FF running much longer without letting you down or hurting your pocket? |
gonfishen Member Since: 18 Jul 2016 Location: melbourne Posts: 11 ![]() ![]() |
No light just warning notice on start up , i got my mechanic to do a full check up ie pre travel check up because of the distances we were travelling |
The car is an 06 RR L322 i spare no expence in service as i am not able to carry out servicing. It is a 3lt desial |
