Home > Technical (L322) > Suspension issues after towing |
L19 MUD Member Since: 02 Jun 2015 Location: Suffolk Posts: 167 |
16th Apr 2019 9:02am |
Could be compressor knackered, if no obvious leak to a bag or pipe .
16th Apr 2019 9:19am |
Previously my suspension raised really quickly so this seems unlikely? I need to give it a check over tonight to see if I can find leaks, just seems odd I don't have one bag going down quickly and its only a bag that would be affected by all that nose weight?
16th Apr 2019 9:33am |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2303 |
The weight on the rear springs may have required more pressure than the compressor could provide to get up to normal height. Locking at access height and staying below the locked speed limit would have been kinder to the compressor.
16th Apr 2019 10:51am |
This is exactly what I tried. I would not have expected this to damage the compressor in any case as the overheat cut out is designed to stop this exact thing from happening.
16th Apr 2019 11:03am |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 416 |
I would check the simple stuff first, check for an air leak on the both front and rear bags.
16th Apr 2019 11:30am |
it won't get anywhere near offroad height - currently does not seem to want to get to normal height.
16th Apr 2019 11:38am |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1131 |
My money is on the compressor being stuffed, had to work extra hard to maintain height with the extra weight? |
16th Apr 2019 12:09pm |
I think you are probably right sadly - no idea on what compressor is in this one so can't order a rebuild kit
16th Apr 2019 12:23pm |
The defender won`t have airbags? I can recommend these guys for help? https://www.rst-landrovers.co.uk |
16th Apr 2019 12:27pm |
LOL - I know my Defender has not got airbags, rather I was complaining that the Defender handles 3500kg no problem!
16th Apr 2019 1:22pm |
Glad you found the problem shame it`s the bag as the compressor would be an easy fix, have you ask Dan at Duckworths? |
16th Apr 2019 1:41pm |
Trying to get hold of him now. Would really like to have the car for the weekend! |
16th Apr 2019 1:43pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2213 |
My front aibag gave way on 10 yrs which is fairly common I replaced both and thepumpr as it was stuffed trying to sort the aipressure out if you do upgrade the pump but remember it needs a software update - done nearly 50k since no problems- good luck |
16th Apr 2019 3:02pm |
