![]() | Home > Technical (L322) > Suspension issues after towing |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
I changed the compressor on mine and did not need a software update maybe because it was only pump that was changed and not the whole unit? |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2281 ![]() ![]() ![]() |
Think you only need the software update if you upgrade the pump usually a change of manufacturer |
L19 MUD Member Since: 02 Jun 2015 Location: Suffolk Posts: 177 ![]() ![]() ![]() |
I think my pump is fine, I watch it on the diagnostics on the way home last night and it was building up pressure no problem until it got hot and then cut out at 280f as it is supposed to do. The car then began to drop until the compressor had cooled to around 220f when it cut back in again.
Jamiehol Member Since: 26 Sep 2014 Location: Ipswich Posts: 230 ![]() ![]() ![]() |
Does sound like the pump is ok given it shuts down at over temp and then cuts back in.
Yes fingers crossed. Not sure if I can get the bag off without taking the strut off the hub?
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
You will have to remove the strut from the car to replace the airbag. .
Well it's off and would have been a doddle if the lower strut bolt wanted to come out! Anyway all ready to go back tomorrow when the bag arrives |
