Home > Technical (L322) > Missing bracket?
Tugger
United Kingdom 2009 Range Rover Westminster TDV8 Stornoway Grey
Missing bracket?
Can anyone tell me if I'm missing a bracket or strap or something in the spare wheel well that holds the jack in place? I think I might be.
Shouldn't there be something attached through those two holes in the carpet and into the metalwork? 09 RR Westminster 3.6TDV8 - Stornoway Grey / Black interior - now gone (sad face)
Nissan X Trail 1.6TDCi Tekna
Fiat 500 1.2
Post #512377 17th Apr 2019 4:08pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Tugger -- the best thing you can do with that is throw it in the bin -- certainly wouldn't try to use it!
If you're referring to the bolt holes that is for the spare wheel lift kit
Hope that helps Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #512378 17th Apr 2019 4:16pm
Weegie
^ +1 John
GAP iiD BT-Sold
Post #512379 17th Apr 2019 4:18pm
Tugger
You mean the jack? Or the whole car? Rolling with laughter 09 RR Westminster 3.6TDV8 - Stornoway Grey / Black interior - now gone (sad face)
Fiat 500 1.2
Post #512380 17th Apr 2019 4:19pm
Bushy30
Just the scissor jack Sir Twisted Evil Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #512382 17th Apr 2019 4:41pm
Tugger
I take it it’s pretty useless then? Not had occasion to use it yet but it does look kind of flimsy now you mention it 09 RR Westminster 3.6TDV8 - Stornoway Grey / Black interior - now gone (sad face)
Fiat 500 1.2
Post #512383 17th Apr 2019 4:55pm
Bushy30
Others report stripped threads, or worse snapped screw thread bar! Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #512384 17th Apr 2019 4:57pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Yes indeed, heard several tales of Fatties "kneeling" down on their brake discs as a result of those jacks, IIRC I saw some mention of a potential class action suit over safety and them being not fit for purpose.
I've also seen on here Sprinter Van bottle jacks with adapted top fittings that go into the lifting points which are much more robust and elegant. Formerly happymadison1978
Post #512385 17th Apr 2019 4:59pm
Tugger
Oh dear that doesn’t sound good at all. Will swing by Aldi later, heard they were doing 2 ton hydraulic lift jacks the other day 09 RR Westminster 3.6TDV8 - Stornoway Grey / Black interior - now gone (sad face)
Fiat 500 1.2
Post #512386 17th Apr 2019 5:00pm
Bushy30
https://www.fullfatrr.com/forum/topic49118.html Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #512388 17th Apr 2019 5:06pm
