![]() | Home > Technical (L322) > IID tool with towball. |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2948 ![]() ![]() ![]() |
I’ve noticed on the IID tool that there is a setting for towball. On mine it says ‘not fitted’ but it has the the factory Westfalia detachable fitted.
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1100 ![]() ![]() ![]() |
Yup, it's a sticker you out in whatever you are towing, camera looks at that and 'adapts' and stabilized based on it's movement in the camera Current: 2011 FFRR Vogue SE 4.4 TDV8
I see. I’ve got electronic stability control on the caravan so might not need it then 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
So apart from the stability assist what other reasons are there to turn on the trailer towball attachment feature in IID when it already works? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
