Home > Maintenance & Mods (L322) > Bottle Jack or Trolley Jack?
Bingo_123
OK so what the minimum height a trolley jack should have to lift the RR safely.
Is something around 465mm enough?
Please confirm
Post #512887 23rd Apr 2019 9:42am
I stick by my earlier advice
Alistair wrote:
I don't know how much height you need, but I'd use the factory jack & measure it for myself Thumbs Up
The factory lack is Censored but good enough to lift the car off the ground on a level surface - particularly if you're not removing a wheel.
Post #512888 23rd Apr 2019 9:52am
Bingo_123
I asked because i am thinking of buying a trolley jack to lift the RR and then put Axle stands.
Just dont like the factory jack and whole turning mechanism and plus i have deployable sidesteps, so was thinking of buying a trolley jack to lift it from the front or back and put axle stands.
thanks
Post #512900 23rd Apr 2019 11:11am
Fraynizzle
United Kingdom 2005 Range Rover Vogue Td6 Java Black
this is the one i have https://www.sgs-engineering.com/tj3lp-low-...olley-jack
its great for lifting the range rover, very solid and stable.
it goes high enough so you can lift it by the subframes and get the wheels off the ground in full droop.
you need a different attachment to lif tthe rear subframe though as the lifting pad doesnt fit between the exhaust pipes where the manual says to lift.
it is pretty heavy though so no good as a mobile jack. perfect for leaving in the workshop though. i got the low profile one too so i can use it on my other 'little' car
Post #512919 23rd Apr 2019 1:57pm
Bingo_123
cheers thanks
Post #512924 23rd Apr 2019 2:23pm
WB
I've gone for this kit - jack goes up to 520mm so should be plenty and over specced 6 tonne (each) axle stands
https://www.sgs-engineering.com/tj3-3-ton-...xle-stands
Arrived today and I can confirm the trolley jack does appear to weigh about 3 tonnes!!
Post #513093 24th Apr 2019 10:17pm
Fraynizzle
can you lift the rear Subframe between the exhausts with that one? how big is the pad?
hahah yes they are bloody heavy but does give you absolutely confidence when lifting stuff!
Post #513123 25th Apr 2019 9:08am
bleeperman
2014 Range Rover Vogue SDV8 Balmoral Blue
What trolley jack? L322 TD6
Its no simple answer I am just sure I am never going to use the scissor jack again! BLOODY SCARY!
SGS wow what a find great kit and good value.
I 've ordered both a trolly jack that is up to the job and a bottle jack for emergency along with a tidy axle stand for safety on the roadside. Oh and always have a long bar with socket the chance of getting wheel nuts undone with the std kit is low.
The miles I do in Wales is the factor here I've lost three good tyres now to stone wall falls!
Post #513130 25th Apr 2019 10:52am
DrRob
I also ditch the locking wheel nuts for standard ones. They will round and fail. I only just got one of mine off - it was well chewed up Censored
Also check all remaining nuts have not swollen. Go round with a 22mm socket and check. They swell with age and the caps on them expand and then you can’t get the socket on Censored Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #513141 25th Apr 2019 1:21pm
Woofster
Canada
DrRob wrote:
Go round with a 22mm socket and check. They swell with age and the caps on them expand and then you can’t get the socket on...
For this reason, I have a set of both 22mm and 23mm hex sockets! 2010 RR SC
2007 RR SC
Post #513157 25th Apr 2019 2:52pm
WB
Sorry just got round to measuring the pad - it's 135mm diameter.
Regarding the SGS Kit - I haven't used it yet but having just taken it all out of the box it all looks to be very heavy duty kit. The trolley jack is an absolute monster. First purchase from them and so far I'm impressed.
I think I'll get hold of a Disco bottle jack for suspension lifts/wheel changes however I'm happier with the trolley jack for high lifting than a tall bottle jack.
I've also got the 22mm and 23mm sockets - that's good advice.
Post #513248 26th Apr 2019 9:33am
