Home > Maintenance & Mods (L322) > Headlight washers
stuartj9
United Kingdom 2006 Range Rover Vogue TDV8 Java Black
Headlight washers
Currently, mine aren't working. Car has Xenons. Is there any common faults? Do they have a single pump or 2? Could it be a fuse? If so, where is it and what number?
Thanks.
Post #514950 11th May 2019 12:59am
Laurie915
Australia 2010 Range Rover Autobiography TDV8 Buckingham Blue
Have you checked the pump is working ? if it's ok; then check the plastic water tubing at the joints starting nearest the reservoir for a blockage and move towards the jets. A lot of times calcium etc will block the jets if tap water was used, so next try cleaning the jets.
Laurie
Post #514952 11th May 2019 3:57am
rjff
+1 with Laurie on fuses, pipes and jets.
I believe there are 3 washer pumps on the car. Have a look in the Wiki for the 2002-10 workshop manual, page 2856 or thereabouts. Sad I know.
The info on fuses etc will be in there too. Cheers
Richard
Gap IIDBT
Post #514974 11th May 2019 12:02pm
stuartj9
Thanks - I'd seen the how to guides but wasn't aware there was a manual to download, so thanks!
I don't seem to be able to see which is the fuse.
Post #515011 11th May 2019 9:05pm
rjff
I wonder if this may help. Found on a webby search for L322 2006 fuse layout.
https://fusesdiagram.com/range-rover/fuses...-2012.html Cheers
Richard
Gap IIDBT
Post #515024 11th May 2019 10:01pm
