Home > Technical (L322) > Reversing sensors on when towing
Andy
So I’ve just hooked up the tintent to get it cleaned after the winter.
I put the car in reverse and the sensors came on. I can turn them off on the dash but I was under the impression that when the towing electrics were plugged in, it disabled the sensors so there was no audible alert.
Anyone know if this is correct? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #515128 12th May 2019 8:19pm
Spooky
United Kingdom 2014 Range Rover Autobiography 5.0 SC V8 Corris Grey
It should. Maybe whoever fitted the towbar didn't alter the setting in the CCF ... Regards,
Mick
'Bertha' - 2014 SDV8 Autobigraphy
'Vincent' - 2010 TdV8 Vogue SE
- 'Molly' - 2005 HSE Auto
'Dixie' - 2000 D2 Td5 ES
Post #515158 13th May 2019 7:06am
Andy
It’s a factory fitted Westfalia though. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #515159 13th May 2019 7:08am
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
Maybe to simple, but I am, if the plug is not really pushed in or if the cable of the trailer has a problem the sensors keep on beeping. Does it show the little trailer on the dash when plugged in?
Post #515192 13th May 2019 12:14pm
Balloonengineer
The air suspension should also be disabled (orange light on switch) when a trailer is sensed as plugged in
That might help to eliminate if it is not sensing something plugged in.
Best wishes
Glen Previously......
Series 1 80, Series 3 88, Turbo 90, 300tdi 90, 110's with 200, 300, TD5
TD5 Disco, Disco 3, 200Tdi Disco - probably the best vehicle Landrover ever made,
Now 3x FFRR, some would say I should have learned by now......
Post #515193 13th May 2019 12:33pm
GraemeS
Australia
The air suspension on MY07 onwards (Terrain Response is fitted) is not disabled when a trailer is detected although automatic selection of off-road height is disabled if rock-crawl is selected.
Post #515196 13th May 2019 12:59pm
Robert
No my air suspension is not disabled when a trailer is plugged in.
Post #515202 13th May 2019 1:48pm
