Home > Technical (L322) > inactive airsuspension messege
pretlove
ive just fitted my new airspring but now i cant turn off the airsuspension inactive messege ive tried the steering wheel trick and ive now disconected the battery and left it for a while ...does anyone know how i can sort this out as my diagnostic equipment will not get rid of this messege and untill it goes i cant test pump my suspension up "RANGEISM WILL NOT BE TOLERATED"
Post #54829 15th Mar 2011 3:46pm
pretlove
bump "RANGEISM WILL NOT BE TOLERATED"
Post #54832 15th Mar 2011 3:56pm
Have you tried taking the vehicle for a run, about 5 miles is recommended.
Not sure if it will work but have heard it does
Post #54833 15th Mar 2011 4:24pm
pretlove
i thought trhat may work but the front is all the way down so not sure if this will do any harm "RANGEISM WILL NOT BE TOLERATED"
Post #54835 15th Mar 2011 4:29pm
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
pretlove wrote:
bump
Gosh you expecting a reply in 10 minutes during the normal working day Rolling Eyes Rolling Eyes
Re-set required - needs plugging in. Question
Post #54836 15th Mar 2011 4:57pm
pretlove
nbunney wrote:
pretlove wrote:
bump
lol that 10 mins felt like hours .....any idea what i should expect to pay to get it pluged in "RANGEISM WILL NOT BE TOLERATED"
Post #54837 15th Mar 2011 5:03pm
Dolphinboy
£55-65
Post #54838 15th Mar 2011 5:06pm
pretlove
i spoke to a few indi's and they all seem to be saying thats what needs doing but i cant get the car to them but when i spoke to land rover they said on that year it should not need reseting.....and said maybe my ride hieght sensor arms are bent but ive checked those and they seem fine plus i cant see how they would be damaged as they was fine before the airbag was changed ....does anyone else have a 2003 range and have had to have theres reset as id be gratefull to here from you "RANGEISM WILL NOT BE TOLERATED"
Post #54844 15th Mar 2011 7:01pm
Take a chance and go for a drive, it can't go any lower than what it is now.
Post #54845 15th Mar 2011 7:17pm
dan_uk_1984
Try the EAS Activate for resetting and code reading.
http://www.rswsolutions.com/index.php?opti...;Itemid=77
Dan
Post #54847 15th Mar 2011 7:21pm
oodathort
I suspect that your air tank is empty you can short the pump to fill or get a compressor to fill but only do this with great care you will find that your system will work again with some pressure in tank but wont work without pressure
Post #54856 15th Mar 2011 7:52pm
pretlove
i did and nothing happend Big Cry
ive been looking at that eas tool i was kinda hoping i could find some software to use on my obd2 tool but so far have had no luck "RANGEISM WILL NOT BE TOLERATED"
Post #54857 15th Mar 2011 7:53pm
pretlove
there is air in the tank but the air system needs recalibrating i think there is a way to get the air into the front bags by using a jumper on the eas ecu "RANGEISM WILL NOT BE TOLERATED"
Post #54859 15th Mar 2011 8:01pm
oodathort
The air valve set up is under the drivers foot well area try swapping the air pipes around to pump up the front or get compressor to pump them up i then think your system will reset if its only front thats down
Post #54860 15th Mar 2011 8:07pm
pretlove
thanks ill give that a try "RANGEISM WILL NOT BE TOLERATED"
Post #54862 15th Mar 2011 8:19pm
