![]() | Home > In Car Electronics (L322) > CarPlay headunit in <MY2005 |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2251 ![]() ![]() ![]() |
Also heads up I wasn’t getting any sound and it turns out the remote wire only outputs 5v which is not man enough for the amp to power up so I used the 12v ignition live from the big plug instead and all is well. I also did a custom loader
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1100 ![]() ![]() ![]() |
Bradders Member Since: 03 Dec 2018 Location: Gods own country Posts: 417 ![]() ![]() ![]() |
Looks the mutts |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
I wish we were so lucky, cannot believe us 2006-2009 ff’s are left in the cold! |
Ur20v - I have down lots of research on this as I am hunting for a 4.2 that era- it is possible BUT you will probably lose your rse[/quote] Current stable:
I know it’s possible but replacing the head unit, amp and doing a complete stereo retire is to much. Just wish for a plug and play head until or cheap mirroring/control module for a android /iPhone apps. |
BMG Member Since: 26 Feb 2019 Location: Kent Posts: 196 ![]() ![]() ![]() |
I'd like an android head unit in my 2002 RR, but seems a minefield on a car with DSP . Add in someone clueless like myself needs true plug & play, and installers don't seem to want to know. |
Rewmer Member Since: 14 Jan 2013 Location: Essex Posts: 142 ![]() ![]() |
Not any more. Search for ibus app and dongle. makes it a breeze. No7 - 2003 V8 Vogue |
Agreed you get the ibus app for the android headunit and the resler interface and you basically get intravee functionality as well like lighting effected door locks steering all works.
OK, that would seem to have solved a large chunk of the problems for a clean install, but as you've mentioned, the odd problem can still occur to leave you with no sound, or the but I'd have no clue on how to resolve. It's a shame Eonon ,Xtrons haven't developed a true plug and play for the electonically useless. |
Was the install much the same as Rewmer posted with his Avin 4 install ? |
pietertje Member Since: 30 Nov 2014 Location: Rotterdam Posts: 152 ![]() ![]() ![]() |
This looks really nice! ![]() |
I can send the photoshop file if you like and is the nova launcher Current stable:
Thanks danwilderspin, please send it to me |
