|  | Home > Technical (L322) > 2011 tdv8 is this normal |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352      | We need a "how to decoke your inlet system" step-by-step guide on here   | ||
|  30th May 2019 6:13am |
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2782    | The throttle will be closed further to ensure that the correct (low) flow through the MAF occurs. | ||
|  30th May 2019 7:25am |
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561      | So responsiveness and performance would be affected would you say Graeme?
|  30th May 2019 12:11pm |
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3888      | Greg,
|  30th May 2019 12:28pm |
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561      | Interesting Mike, I'm still trying to understand the root cause of soot / DPF fill.
|  30th May 2019 12:42pm |
|  30th May 2019 1:04pm |
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561      | Yes you're right Mike. I'm reaching 17.5g or even 20g for every tank of fuel.  i.e. I'm having to do a regeneration per tank.  Some tanks I don't get out of town so I can't get a 'natural' region within my tank cycle.
|  30th May 2019 1:13pm |
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3888      | I have tried putting additives in just after topping up, but found over a 4-5 month trial period they make no noticeable improvement , but I do always use supermarket standard diesel.
|  30th May 2019 1:38pm |
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561      | What's your actual tank range Mike, do you set your trip when you fill up?
|  30th May 2019 1:51pm |
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3888      | Yes, every time.
|  30th May 2019 2:00pm |
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561      | 500 miles is very good Mike.  But I'm not sure the miles remaining is accurate at all.
|  30th May 2019 8:33pm |
| All times are GMT | < Previous Topic | Next Topic > |
| Posting Rules
