![]() | Home > Technical (L322) > Oil level sensor questions |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4351 ![]() ![]() ![]() |
This morning with a cold engine I was able to check the level without opening bonnet and doing the double cruise control click.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3883 ![]() ![]() ![]() |
Both are right.
So I can check level when cold in morning without bonnet open or double clicking? Is that right?? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Yes, that is the correct method to check the level., ie bonnet closed, but before starting the engine.
I check mine first thing in the morning whilst car is still in garage because my drive is on an incline and garage is only level area.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561 ![]() ![]() ![]() |
Thanks Mike, I never knew I could do that.!
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
DrRob,
Nino
