Home > Technical (L322) > Test pulse flashing on LED headlights |
RaveRover Member Since: 14 Mar 2017 Location: Melbourne Posts: 36 |
Hi.
12th Jun 2019 7:53am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34871 |
led headlights?? any pics. |
12th Jun 2019 8:09am |
Yep, I'll post some..
12th Jun 2019 8:54am |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 816 |
Isn’t this hot or cold checking of the bulbs, I can never remember which one
12th Jun 2019 10:26am |
gj88 Member Since: 10 Sep 2018 Location: West Midlands Posts: 213 |
Yep, if you have one turn it off with IID.
12th Jun 2019 10:43am |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 774 |
I have Led bulbs in mine ( they are great). You have to fit both a load resistor and a relay to stop the flashing. The 2v test pulse won't be enough to trigger the relay, it will only switch on with a full 12v. I also have automatic white daytime running lights that switch to orange indicators that flow in the direction of the turn fitted inside the headlamps 2007 TDV8 VSE
12th Jun 2019 11:04am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16146 |
Simply turn off the hot & cold monitoring in the CCF files... DO NOT use resistors as they create LOTS on heat and this is BAD! and even worse when the resistors burn out!!! |
12th Jun 2019 12:01pm |
Lol. I dont have a spare $700 laying around Once you've driven a Range Rover, everything else seems 2nd rate.. Eeeek I'm trapped for life. 1986 RRC Highline with offroad mods. Arctic Silver 2001 P38 HSE. Ardeness Green. 1995 RRC soft dash (beautiful car) Green. 2005 L322 HSE V8. - Current, most awesome car yet. And most expensive. |
14th Jun 2019 9:28am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3951 |
I just let mine flash, never worried about stopping them. |
14th Jun 2019 9:59am |
That's not uncommon, my main point was that it'll pay for itself in the long run, and I wouldn't faff about with other solutions. My advice would be let them flash for a few months while you save, and then turn it off at the flick of a switch |
14th Jun 2019 2:43pm |
Short video of the flashing : Once you've driven a Range Rover, everything else seems 2nd rate.. Eeeek I'm trapped for life.
16th Jun 2019 3:21am |
Short video of the flashing here Once you've driven a Range Rover, everything else seems 2nd rate.. Eeeek I'm trapped for life.
16th Jun 2019 4:35am |
finchi Member Since: 25 May 2017 Location: Hampshire and Cheshire Posts: 120 |
If the monitoring is turn off using the IID, then I guess you lose the functionality of the lamp test with its obvious safety and convenience factors? |
16th Jun 2019 7:01am |
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 282 |
Hi I also have this issue I retrofitted halos in my headlights and I get the same a flashing for about 5 seconds when ignition is turned on. Where about in the CCf is the option to disable the hot and cold function and can disabling this cause issues? Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
17th Jun 2019 2:56pm |
