![]() | Home > Off Topic > Removing oil stains from concrete |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3858 ![]() ![]() ![]() |
Domestos household bleach is as good as anything.
BMG Member Since: 26 Feb 2019 Location: Kent Posts: 196 ![]() ![]() ![]() |
Not sure about concrete, but don't imagine it's much different, but by Farther reports did a good job on his block paved driveway.
Anvil Member Since: 18 Jan 2019 Location: Dorset Posts: 140 ![]() ![]() |
Brake cleaner is also a good tip. Gets oil our of pretty much anything. Do a test on an inconspicuous part first though! Also Cat litter in a big spill. Sucks it right on up.
Balloonengineer Member Since: 03 Sep 2017 Location: Kent Posts: 180 ![]() ![]() ![]() |
Household Caustic Soda and a stiff brush, works a treat, will make your drive cleaner than the clean bits!
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
You need a detergent to remove the oil/grease .
jim4244 Member Since: 31 May 2012 Location: UK Posts: 855 ![]() ![]() ![]() |
Bicarbonate of soda mixed with vinegar.
Boxbrownie Member Since: 19 May 2018 Location: FF gone now....FL2 i6 to play with Posts: 245 ![]() ![]() ![]() |
Cats |
chugga90 Member Since: 24 Jul 2015 Location: Chilterns Posts: 157 ![]() ![]() |
A neighbour once used Petrol and a box of matches.
