![]() | Home > Technical (L322) > K-Bus Location? |
Any idea where I can tap into the K-Bus?
Hi Matt,
Tried looking as well Dan, could only find this , if you scroll down to about half the pages ......page 8 i think
Thanks Mick, no joy though.
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 ![]() ![]() ![]() |
hi dan, why you after the kbus, i now have the bmw sss up and running V8 facelift Range Rover Autobiography 22" wheels.
Trying to communicate with the fbh... this runs on the k-bus with the rest of the hevac system.
oodathort Member Since: 01 Nov 2010 Location: just there Posts: 191 ![]() |
Hi can you tell me more on the bMW sss please |
Could be wrong here (as usual) guessing that early L322's might have the same bus set-up as BMW while looking through a Land rover website came across this link , and if you click on the left menu on BUS troubleshooting and scroll about halfway down the page it will show you diagrams .........
Has anyone got software to acsess the i bus i have a resler interface and have navcoder but want to go deeper ??? |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
What do u mean you want to go deeper? What do u want to do? Matt |
Get acsess to more than the lcm and nav ecus |
Can you start a new thread, or append to one of the old iBus threads please. This is for the location of the K-Bus. To help you on your way, check this out: http://www.fullfatrr.com/forum/topic1797.html It touches on the subject of manually injecting iBus commands into the network. ![]() ![]() |
You can't really access anything else as there is not that much more on the ibus. To access the diagnostic side of the units on the ibus you need a diagnostic tool like faultmate or rover com etc... The ecus on the ibus Nav computer TV module Radio module Phone ecu Voice control etc PDC module Instrument cluster Rain sensor LCM module DSP or standard amp Cd changer Centre console screen or MID There are links to other ecus e.g. BCU, mirrors etc... But these are not diagnostic links to access any diagnostic links you need the proper equipment. Matt |
It's easy to manually inject ibus commands you can use either navcoder or ibus analyser which was designed for bmw's but works great on the range rover Matt |
