Home > Maintenance & Mods (L322) > MOT standards
Bradders
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
MOT standards
My L322 passed its MOT today with an advisory that the N/S and O/S brake pipes are covered in grease.
That wasn't mentioned on last years MOT and I haven't covered them increase in the meantime, so that means either the last tester was a bit slack or todays tester was a bit keen. Either way that's not too clever. Current: FF Westminster money pit
Gone:
RRS 4.2 SC
RRS 3.6 TDV8
FL2 TD4
Post #519918 28th Jun 2019 11:28am
Baltic Blue
Brad,
Coincidence, mine passed the MOT on Tuesday... the tester made special mention to the brake pipes being coated in Dinitrol, which the same man never made any similar comment last year, but he did say we see a lot of these failing on rusty brake pipes, but these are OK. ?.
Post #519924 28th Jun 2019 11:47am
Bradders
Thanks Mike - i am waiting for a call from the garage to see what they think. They use an independent MOT garage as they don't do MOT's themselves.
Surely it's a preventative measure so what's the problem in any case ? Current: FF Westminster money pit
Gone:
RRS 4.2 SC
RRS 3.6 TDV8
FL2 TD4
Post #519927 28th Jun 2019 12:19pm
Nothing wrong with having brake pipes covered in grease provided the pipes were in good condition when the grease was applied.
If you really want to get an mot tester going try greasing and then taping up the exposed sections of brake pipes in the wheel arch areas with self amalgamating tape. Again provided the brake pipes are in good condition before it is applied they will never corrode.
Just an extension of what manufactures do with plastic coating of pipes.
Good for an advisory or two though which can be safely ignored. Thumbs Up
Post #519929 28th Jun 2019 12:24pm
Bradders
Thanks chaps. This confirms what the garage are saying too. Bow down
They just called and told me to ignore the advisory. Given they would be doing any work on the car I am happy to take their advice. Current: FF Westminster money pit
Gone:
RRS 4.2 SC
RRS 3.6 TDV8
FL2 TD4
Post #519932 28th Jun 2019 12:41pm
Baltic Blue
All a bit pointless really . You should have see the state-of-the old brake pipes I took off my L322 Td6 Vogue.
Most of the corrosion is out of sight, hidden behind the plastic covers.
Criminal really that they don’t use Cunifer from new.
Post #519935 28th Jun 2019 1:00pm
Bradders
How unreasonable of you Mike, bearing in mind these cars are designed for the rough stuff Whistle Current: FF Westminster money pit
Gone:
RRS 4.2 SC
RRS 3.6 TDV8
FL2 TD4
Post #519945 28th Jun 2019 1:55pm
m@ttsFF
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
The advisory is due to the tester being unable to confirm the condition of the pipes under the grease. 4.2 SC - sold , now bought back
4.4 AdBlu Tractor - Stolen
Post #519988 28th Jun 2019 9:35pm
Mikey
As above. MOT tester has to cover his arse, should a brake pipe fail, in a place that cannot be accurately assessed or seen...
Post #519998 29th Jun 2019 5:46am
gettingold
My regular tester retired so I had to use a local garage. It was in getting tested and a mechanic came into reception and spoke with the receptionist. He said that he (the mot tester chap) wants to fail (another car)the car on bushes, but we only fitted them in Feb so we’ve encouraged him not to fail it. I won’t be going there again.
Steve.
Post #520002 29th Jun 2019 7:26am
ur20v
A Trap
MOT testers can only inspect what they see and are not allowed to remove coatings etc, as mentioned above, they will sometimes put an advisory on something looking suspect to cover themselves which is fair as there a lot of dodgy ‘ fixes’ done to get a car through an MOT by owners and garages.
If you don’t want an advisory you could either remove the grease prior to the MOT and cover again post MOT which would be a good thing in reapplying regularly. Or give the MOT inspector permission to remove but note, they can refuse to do this.
Post #520094 30th Jun 2019 8:41am
Bradders
My main point is there is no consistency in testing standards and that has cleary been confirmed by others experiences. I havent greased them since last years MOT which made no reference.
The tester couldnt see the brake pipes as they are covered and therefore he did not know if the grease is an attempt to hide corrosion or is just preventative. By putting an advisory on the certificate it appears there is a potential issue where there isn't one. Current: FF Westminster money pit
Gone:
RRS 4.2 SC
RRS 3.6 TDV8
FL2 TD4
Post #520104 30th Jun 2019 9:43am
ur20v
A Trap
When humans are involved you will always get different outcomes, even with the same human!
I would take some comfort in your latest tester having his eyes open and commenting on the grease although that is no guarantee that he didn’t miss something more serious. That’s why get your car serviced and inspected at least yearly is a good idea, also not always using the same tech can also be a good idea... saying you use your tech because he ‘knows’ the car could be a bad thing in that he may become complacent through familiarity
Post #520126 30th Jun 2019 12:22pm
