Home > Maintenance & Mods (L322) > Split boot on right offside CV joint
Rambles
Just starting to weep grease
Stealer wants 370.
Home DIY thoughts?
I don’t see the need for any particular special tools....
Post #520120 30th Jun 2019 11:52am
GGDR
Lower ball joint while it's all apart?
. Cheers, Greg
Post #520124 30th Jun 2019 12:19pm
Front or Back, Inner or Outer ?
You will need the correct socket (36mm 12pt) and a decent length/size breaker bar to undo the hub nut, if it is not rusted away...
https://www.fullfatrr.com/forum/topic47969.html .
Post #520129 30th Jun 2019 12:26pm
Andy
I’ve got this lovely job to do this week. I’ve bought a new GKN CV gaiter.
I’ve done a few driveshafts in the past and I’ve always removed the CV joint in situ - leaving the main section on the car. Has anyone managed to do this on a full fat? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #520853 6th Jul 2019 2:30pm
