![]() | Home > Technical (L322) > Adaptive Dynamic Fault L322. |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 502 ![]() ![]() ![]() |
Air suspension working as it should? Cheers
Mikem Member Since: 13 Jan 2019 Location: Kent Posts: 48 ![]() ![]() ![]() |
Hi thanks for your reply, yes all suspension working fine |
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 ![]() ![]() |
Hi Mike, had this on my L322 S/C and fixed it with the wiring kit (x2). Assume it's the Adaptive Dynamics fault, not Active Dynamic. Happy to pop round and take a look depending on where you are in Kent!
Hi Andy yes it’s the adaptive dynamic fault, I am down in Folkestone many thanks for the reply |
Ha, my home town and where I was dragged up (Dolphins Road)! Can arrange a visit in the next couple of weeks if you need some help I am popping down to visit my Dad in Seabrook in the next couple of weeks. PM me |
Will do many thanks for your reply
Forgot to put i am only about 5 mins from Seabrook |
Checked the connections yesterday on the 2 new wiring repair kits and all seemed ok but the warning light is still coming on could there be another fault has anyone else experienced this |
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 ![]() ![]() ![]() |
Have you confirmed it was definitely the fronts with a iidTool or similar?
Had a broken wire on the front so replaced both sides going to get into somewhere that can plug it in and hopefully trace the fault. Thanks for the reply |
What did you have to replace on the rear of the car |
I had to replace the wiring & connector.
Cheers rob will check tomorrow i have a spare repair kit if required |
Checked the rears tonight no broken wires at the plugs so i think next thing is to get it plugged in and see what comes up |
